ot -ford
James Williams
08-06-2006 14:20:02
I am working on a ford pick-up that the orginal motor has been replaced with a 351 that has a vaccum distributer.can some one tell me the tune up specs
1-plug gap
2-point gap
3-timing degrees
RPM at what degree timing
or ect.
the tractor vet
08-06-2006 20:53:22
 Re: ot -ford in reply to James Williams, 08-06-2006 14:20:02
The correct setting are on the points on a ford V8 is .017 and plugs on a dist with standard coil set up is .035 and on the timing it can be anywhere from TDC to +10 degrees with all vac.lines off and pluged at curb ideal and that can be depending on year again from 525 to 750 . now this is comming out of the back room with all the cobb webs from when i worked on fords but some things ya never forget.
Janicholson
08-06-2006 15:53:35
THere are a bunch of 351 engines Both Cleveland design, and Winsor Canadian Design. There are also a bunch of differing tuneup specs due to the farious states of tune, and the type of Ignition system it has. The best bet is to find out what it came out of, and if anything was changed that would affect the tuning. No direct answer here, sorry, JimN
teddy52food
08-06-2006 15:50:53
Might make a difference of what year. Points should be good when you have 30 degrees dwell. Plug gap is .035.
