H question
Reno
08-07-2006 08:38:49
I'm looking at a 51 H. are they 6v or 12v system? thanks
reno
08-07-2006 09:07:58
 Re: H question in reply to Reno, 08-07-2006 08:38:49
thats the problem there is no battery on the tractor and didn't know which to buy
old
08-07-2006 09:10:32
 Re: H question in reply to reno, 08-07-2006 09:07:58
Look up under the hood on the right side and see if it has a genny or an alternator. If it has a genny its most likely 6 volt and if it has an alternator then its 12 volts. Also if it has a genny it will be + ground and if it has an alternator it will be - ground
El Toro
08-07-2006 08:54:45
They were originally 6 volts, but it may have been converted to 12 volts. If the battery is on the tractor count the cells. That's 3 for 6 volts and 6 cells for 12 volts. Hal
