valve numbers
banjo
08-07-2006 17:45:09
I am trying to get the numbers on the valves. the intake are easy to read 57797-D. the exhaust look like 57798-? looks like it might be a D also. does that sound right?
I looked on the parts section for my year model and the ones it shows are 4.94" mine are not exactly. some little longer some, little shorter.
just wanted to see if the numbers sounded right. I'll be getting the complete overhaul kit and it asks for the valve numbers.
magman
08-07-2006 19:42:31
 Re: valve numbers in reply to banjo, 08-07-2006 17:45:09
what tractor is that? Let me know and I can help. If its like an H there are two different size valves. And are far enought apart in lenght to know what ones you have even if there worn a little. Why did you not ask me for a price on a motor kit. JON
banjo
08-07-2006 21:28:59
 Re: valve numbers in reply to magman, 08-07-2006 19:42:31
It is a 1948 super A. 4.94 & 4.95 on 2 of the valves i have in my hand.
Didn't know you had prices on kits. already hit the order button. are they better than these on this site?$504 plus shipping for my year model.
will have a cub to do next, probably be a while till i can afford to start it.And a 52 super a thaqt is going to need some work also. But need other things first.
magman
08-08-2006 07:57:53
 Re: valve numbers in reply to banjo, 08-07-2006 21:28:59
PROBLY COULD HAVE SAVED YOU $100. TO $150.00. MY BOOK ONLY SHOWS ONE SET OF VALVES FOR A SA with the C123 If its a C113 and the seial is between 255,000 and 310,000 it will have two different valves those serials use the 4.94" valves JON
banjo
08-08-2006 10:46:13
 Re: valve numbers in reply to magman, 08-08-2006 07:57:53
yes it fits in that range of serial numbers. I sure would of liked to save that much money. just my luck i guess. but it is that way for everthing it seem . day late dollar short.
magman
08-09-2006 03:48:03
 Re: valve numbers in reply to banjo, 08-08-2006 10:46:13
Just get ahold of me the next time. JON
