B414 hyd. oil
Scotty1
08-07-2006 18:42:20
Hi, where do you check the hyd. oil on a B414 ? Is the hyd oil trans oil and diff. oil checked in the same spot ? Thanks for your time and any help
Scotty
Fromjb2
08-07-2006 20:54:10
 Re: B414 hyd. oil in reply to Scotty1, 08-07-2006 18:42:20
Hi Scotty, Hydraulic oil is checked thru the filler plug in the casting behind the seat. From Operator's Manual: Hydraulic Oil, Remove plug and check oil level. Top up until the oil is level with the top of housing. Use Hytran hydraulic oil.
Transmission use 80 or 90wt gear oil. Filler plug is beside gear shift. Level check plug is beside brake pedal and floor board. Correct level is bottom of check plug.
Hope this helps
JB2
