123 oil pump
R Fink
08-08-2006 20:10:21
removed the pan and oil pump found the pickup screen is floating up until it hits the pump . is there supposed to be a stop that will allow the screen to float up so far ,if so how far ??
R Fink
08-09-2006 10:35:37
 Re: 123 oil pump in reply to R Fink, 08-08-2006 20:10:21
i have the 2 ears on the screen , but the stop that the ears catch on on the end cap of the pumpis missing . any body have one lay ing around you could take a pic of ??? What is the idea of the pickup tube pivoting??? in the I.T. manual they call it a floato screen .
El Toro
08-09-2006 14:34:51
 Re: 123 oil pump in reply to R Fink, 08-09-2006 10:35:37
Did you read the postings under Keith about being secured with a cotter pin. Hal
PS: Thats just below your posting
El Toro
08-09-2006 04:24:26
That may be your no oil pressure problem if that pickup screen is tilting away from the oil level in the pan. Should be a snug fit into the pump
as Keith mentioned. Hal
Keith-OR
08-08-2006 23:43:02
 Parts Manual Pic. in reply to R Fink, 08-08-2006 20:10:21
R Fink, I don't see anything in the parts manual of a float stop. It appears to me that it is a force fit (snug) almost a press fit...HTH
Keith & Shawn
third party image
Red Dave
08-09-2006 06:15:28
 Re: Parts Manual Pic. in reply to Keith-OR, 08-08-2006 23:43:02
It is not a force fit. the float moves up and down freely. The float is held in place by a cotter key. It is not all that appartent in the illustration, but there are two "ears" on the float that contact the pump body to limit up and down travel.
Hobo,NC
08-09-2006 05:20:24
third party image
pix
Hobo,NC
08-09-2006 05:08:31
I have 2, 123 pumps and both have a stop to keep the pump from going to high or to low. The stop is made on the pick up. Also the pick up is retained by a cotter pin. The stop and the cotter pin hole kin both be seen in your pix. Is mine correct I dunno, the one in my 100 is the same rebuild a little over a year ago. Only thing I have noticed is it takes 5 sec. Or so for pressure to build up on cold start, other than that no problems and good O/P. Interesting Cuzz I would have thought the pick up would have been secured to the pump body and why these swing I dunno. BTW the pick ups will swing up and down in a 6” till it hit’s the stop on the tube.. I have owned the 100 for over 15 years and no O/P problems. I have a parts engine and its that way so assumed that wuz the way they were made.
Jack in Ohio
08-09-2006 05:08:00
It is supposed to float,not stay stationary. The tube of the screen is inserted into the pump and a cotter pin keeps it from coming out. There are 2 small fingers on the tube that hit the pump cover to limit the travel of the screen. maybe your 2 fingers are broken off?
Jack
Hobo,NC
08-09-2006 05:21:35
 Re: Parts Manual Pic. in reply to Jack in Ohio, 08-09-2006 05:08:00
glad to here that I did not wont to drop the oil pan
