544 engine
al rice
08-09-2006 06:58:13
Have a 544 IHC gasoline engine,I'am getting water in the engine oil, does this engine have wet sleeves. Just done the head ,machine shop checked for cracks and resurfaced, done a valve job, still the same problem. Any suggestions? help.
the tractor vet
08-09-2006 07:42:31
 Re: 544 engine in reply to al rice, 08-09-2006 06:58:13
Drop the pan if ya have the engine all back together and fill the rad and pressure it up place a clean pice of cardboard under the tractor and let her drip and look up and you may see where it is dripping from my be a cracke block in one of the cyl.
BillyinStoughton
08-09-2006 07:06:24
The C-200 in your 544 is a sleeveless type block. I would double check the work already done and at that point look at the block. I would start with a compression test and try to narrow it down to a particular cylinder, or a particular two adjacent cylinders.
I hope you find something simple!
Billy
