fuel sending units
Alvin NE WI
08-09-2006 19:11:33
Got a 986, dual tanks, fuel gauge hasn't been dependable with its readings, tryed a different gauge, didn't help, put in new sending units and it doesn't help, took a voltage reading at sending unit wire and got a reading of 6.6 volts. Is that what it should be? I thought it should be 12.6 just like battery reading. Is there anything to cut the voltage going to the sending units?Any help appreciated. thanks Alvin
Michael Soldan
08-10-2006 06:17:56
 Re: fuel sending units in reply to Alvin NE WI, 08-09-2006 19:11:33
My experience with fuel guages and sending units is mostly automotive but I agree 100% with tractor vet, if the ground for the guage and sending unit is not good the unit/guage won't work. Most fuel guage failure in autos is from faulty ground wire. Good luck...Mike in Exeter Ontario
Brownie 45
08-10-2006 04:58:14
On the 240, you can get a small 3 terminal voltage regulator which is used in electronic applications that will give you a steady 6 volts regardless of input voltage up to 32 volts. It is a Motorola unit MC 7806 ct. Should be available for less than $2 at most supply jobbers. Postage will probably be more than the unit. Left terminal is volts in positive, middle terminal is gnd[negative], & right terminal is volts out[6 volts].
GA Dave
08-09-2006 20:26:41
I've been waiting for something on fuel gauges/sending units to surface. I was, before retiring because of health problems, a non restricted state licensed electrical contractor class II and unrestricted low voltage contractor (no TOOT TOOT intended). Nothing I ever studied had to do with tractors or cars. Always indrustial. I take notes and remember that John T is a electrical engineer but might have been on the bigger end also?. Question. I changed my IH 240U to 12 volts negative ground and would like to get the fuel gauge working after the restoration. I have checked the ballast resistor out and don't think that will even come close to putting six volts on the gauge. I would think I need a small ? OHM resistor inline to the gauge from the 12 volt battery. I'm open to any suggestions. I've been using the old standby hickory stick and it never lies. GA Dave.
the tractor vet
08-09-2006 19:24:13
They can be a pain in the donkey to get working as they both have to work together or they don't work as far as voltage i can not tell ya off had as i have never took a reading on them . If it works when full and when the top tank is empty it goes to empty the the bottom tank sender is the problem , now it may be a ground that is giving ya trouble so check for good grounds.
