Farmall A Cold Valve Gap
CaptainCarl
08-10-2006 03:29:13
My IT book states to use set the hot tappet gap to .014 hot. Does anyone know what cold gap will provide .014 hot ?
thanks
Greg-N-CA
08-10-2006 06:06:55
 Re: Farmall A Cold Valve Gap in reply to CaptainCarl, 08-10-2006 03:29:13
The rule of thumb that I have always followed over the years (on many different engines) has been to add .002" to the hot setting. After the engine is warm, adjust the valves to the hot specifications and you're good to go.
Good luck,
Greg
Red Dave
08-10-2006 05:17:59
About .016-.017 cold will be very close to .014 when it warms up.
I reccomend that you don't just set them cold and assume it is OK. I always recheck them warm to be sure.
Mikey D
08-10-2006 03:50:58
I believe somebody asked this same question about a month ago and the answer provided was .017.
mike
