starter button location early super m
Soldner
08-10-2006 05:07:46
I was wondering if anyone had a picture of the location of the starter button for a early super m?? I also was wondering what is the correct size tires both front and back for a Super M? What books could help me? Thanks
Soldner
08-10-2006 05:51:36
 Re: starter button location early super m in reply to Soldner, 08-10-2006 05:07:46
Thanks.. Is the super M a 6 volt positive ground system? I also was wondering where the voltage regulator is suppose to be? On the generator, or on the front gas tank support.. A picture of a late M, or Stage I SM instrument panel area would be great.
jaybird2
08-10-2006 05:19:00
I have a Stage 1 Super M. Starter button is located just behind the steering post. Foot operated lever contacts the plunger to open the switch. I believe this was standard.
Standard size front tires are 6.00 X 15. Rears on mine are 14.9 X 38. I believe the IH tractor data book would have the factory standards.
scotc
08-10-2006 18:44:22
 Re: starter button location early super m in reply to jaybird2, 08-10-2006 05:19:00
Mine is an early SM and it's got a rod to pull that's right under the choke rod, both bent into loops on the end. My regulator is on the steering post, right where it's easy to kick when it sticks.
