Super M - 6 or 12 volt
Soldner
08-11-2006 05:45:45
Are Super M's 6 volt or 12? I'm assuming there 12 volt, but no battery, so i'm not sure.. Is it positive ground? Thanks
Soldner
08-11-2006 08:33:59
 Re: Super M - 6 or 12 volt in reply to Soldner, 08-11-2006 05:45:45
Thanks guys. Don't worry, i'm not a fan of 12 volt conversions either.. I just wanted to make sure it was a 6 volt positive ground. Thanks.
John T
08-11-2006 06:47:45
Soldner, Im NOT a fan of 6 to 12 conversions or alternators (especially on smaller tractors but the M could be the exception) Sooooo ooooo oo to start a Super M (if it was indeed originally 6 volts??) and especially at cold temperatures using a 6 volt battery, Id suggest the biggest heaviest highest amp/hr and CCA rated battery that physicsally fits plus the use of 00 Gauge battery n starter n ground cables and have the ignition and carb all in tip top shape.
John T
Andy Martin
08-11-2006 06:38:52
Super M was 6v positive ground, although you can put a 12v in, negative ground, if you need a generator too. An alternator is just alternating generator, by the way.
jal-SD
08-11-2006 05:53:45
Dad's '53 SM-LPG was 6V, had to have the biggest 6V made to turn it over as it had lots of compression. Like all letter series, it was + ground. (My $0.02 worth. jal-SD)
BDM
08-12-2006 20:39:54
 Re: Super M - 6 or 12 volt in reply to jal-SD, 08-11-2006 05:53:45
I recently had my factory generator rebuilt to 12v along with a new 12v regulator. Converted my tractor from 6v +/ground to 12v -/ground. You can't tell except for the 12 Delco battery :-)
Brian
