CharLyn for SMTA
GordoSD
08-13-2006 07:49:11
I just removed the CharLyn PS from my tractor because someone had mounted it on the steering shaft closest to the operator. Looked like the devil hanging there. I'd like to install it under the hood, on the forward shaft.I think I need a special gage cluster, or a bracket that bolts to the existing gage cluster. Does anyone have one? Or a good photo of what I need?
Gordo
BIG JOHN
08-13-2006 18:34:12
 Re: CharLyn for SMTA in reply to GordoSD, 08-13-2006 07:49:11
Go to E-bay item #250017967945, just put up for auction and it is just what you need.
GOOD LUCK
randy hall
08-13-2006 08:53:27
yes you will need the charlyn gauge mounting braket.
Steven@AZ
08-13-2006 08:26:26
On a SMTA, the CharLynn torque motor should mount without any special brackets. Just remove the cast bearing and cut the shaft to the right length.
Are you sure you don't have a Behlen torque motor?
Here is a pic of a CharLynn torque motor with the angled bushing for an H (arrow):
third party image
