extra rings?
banjo
08-13-2006 08:08:05
Received the overhaul kit and they sent rings for 4 groove piston and the new aluminum piston only has 3 groove. Wrong rings or just the norm.
Nebraska Cowman
08-13-2006 11:12:53
 Re: extra rings? in reply to banjo, 08-13-2006 08:08:05
I'd say wrong rings. If the width is correct you might discard one of the center rings but the top and bottom will have to match.
banjo
08-13-2006 11:31:21
 Re: extra rings? in reply to Nebraska Cowman, 08-13-2006 11:12:53
will have to check them out and see it they mic out. anyone else order overhaul kit from this site with the same situation?
magman
08-13-2006 12:54:56
 Re: extra rings? in reply to banjo, 08-13-2006 11:31:21
Send them back.Uless its somthing to do with the oil rings. jon
banjo
08-13-2006 21:00:20
 Re: extra rings? in reply to magman, 08-13-2006 12:54:56
it is an extra oil ring according to the markings on the package.
