Question about rear rim for 400 ?
J Muehring
08-13-2006 13:24:45
I bought a used rear single bevel rim,thought to have came off Oliver. Will it work in place of dlb bev rim I have on Farmall 400 ? Next question, I want to put a used 13.6-38 on that Oliver rim but its one inch wider than rims presently on 400. Will mounting on the wider rim damage the tire ? The tire is good except where it spun and cut the lugs. Thanks.
dej(JED)
08-14-2006 05:20:31
 Re: Question about rear rim for 400 ? in reply to J Muehring, 08-13-2006 13:24:45
You need a double bevel rim. What model Oliver did the rim come from? I have never really heard of a single beveled rim before. With tires you can get away with a tire that is about 2 sizes wider than the rim. One inch wider is recomended as is the exact size rim.
