Rebuild My Own MCV Pump?
Harlen Larson
08-13-2006 19:36:15
My manual talks about rebuilding the mcv pump for my 806. Is this an option or can't I really do what it needs myself. What goes wrong with them anyhow? Otherwise I found an aftermarket for $240. Is this a good idea or should I go with a reman? Thanks again guys!!
Harlen Larson
08-14-2006 04:58:13
 Re: Rebuild My Own MCV Pump? in reply to Harlen Larson, 08-13-2006 19:36:15
So far i'm just going by what others have told me in my previous post. I sure would like to put a gauge to it. What pressure should I have and how do I do it?
El Toro
08-14-2006 07:19:28
 Re: Rebuild My Own MCV Pump? in reply to Harlen Larson, 08-14-2006 04:58:13
Doesn't your manual list the hydraulic pressure?
It should show where you would install a pressure gauge. Your gauge should have a higher range than the expected pressure so you don't ruin the gauge with excessive pressure. You may need to use a short piece of hydraulic hose that will withstand the pressure. You will also need the
tube fittings so you can connect the hose to the pump and to the gauge. Be careful around that high pressure. My manual only covers the lettered tractors and they had some pressure in the 1100-1500 psi range. Your pressure may be higher than this. Hal
the tractor vet
08-13-2006 19:46:11
First off what make ya think that ya need a new or rebuilt pump // Have ya put a gauge to it ?? If ya need a pump then it's a whole bunch easier to just remove 4 bolt and install two O/Rings and be done with it .
