Farmall 340 Loader Hydraulics
Larry Hardesty
08-14-2006 06:55:00
I have been moving some dirt and gravel to get a building site ready as a shop and storage area for my tractors. The 2001 loader on my Farmall 340 has trouble picking up a bucket load of dirt. It is a small bucket. While I have not moved dirt for awhile, I don"t recall this problem in the past. The seems to be plenty of fluid and I do not hear any strange noises. Anything in particular I should be looking for? Thanks in advance.
Nat 2
08-14-2006 08:23:08
 Re: Farmall 340 Loader Hydraulics in reply to Larry Hardesty, 08-14-2006 06:55:00
You can borrow a hydraulic pressure gauge and a flow rater to test your system, then rebuild or replace the pump.
You can guess that the problem is a bad hydraulic pump, and rebuild or replace yours.
Weak and slow is usually a weak pump, though there could be a restriction or clog in the system somewhere...
