350U 12 or 6 volt
K. B. in Pa.
08-14-2006 16:42:06
Can anyone tell me if a 350U is 12 volt or 6 volt from the factory. it has a gen. with the numbers 11 00531 stamped into the body of the gen. and the numbers 11 0531 0m2 stamped into the tin plate on the gen. It also says delco-remy on the tin plate. I can't read anyting on the reg. or the starter. It is pos. ground. Gen looks to be original but who knows. Thanks!
CNKS
08-14-2006 20:08:12
 Re: 350U 12 or 6 volt in reply to K. B. in Pa., 08-14-2006 16:42:06
Based on what the others said (I was not aware that 12 volt was an option, but should have know it because it appeared on the 450 during production) If there is paint on the gen tag, black is 6, red is 12, not saying that is foolproof, though. I assume it has no battery -- 3 cells=6, 6 cells=12. The voltage could be stamped on the bottom of the regulator, if original or an exact duplicate, you may have to remove it to tell.
CNKS
08-14-2006 20:13:51
 Re: 350U 12 or 6 volt in reply to CNKS, 08-14-2006 20:08:12
Jim posted 2 minutes before me -- he just gave you the answer.
Jim Becker
08-14-2006 20:06:12
A 350 may have been either 6 or 12 volt, depending on how it was equipped. I assume your generator is actually 1100531, which is a 6 volt unit.
superman
08-14-2006 19:32:07
The 350 Diesels were all 12 volt....Superman
350 HU Don
08-14-2006 18:53:14
The 50 (350, 450) series tractors could be specified with 12 volt from the factory. If not specified, they were 6 volt. My 350 HU was 12 volt from the factory.
CNKS
08-14-2006 17:14:31
6
