Starter Rebuild Delco-Remy # 1108918
zax
08-15-2006 06:35:25
Hi, i have a Delco-Remy (1108918) starter on my wd-6 tractor and need to know where to find a bearing and brush kit for it. Also where is the engine serial # located? Thanks!!
Bob
08-15-2006 15:32:42
 Re: Starter Rebuild Delco-Remy # 1108918 in reply to zax, 08-15-2006 06:35:25
Have you tried the CNH dealer? I have gotten starter parts for tractors nearly that old overnight through the dealer, and the price isn't too bad, either.
Hayfarmer
08-15-2006 12:38:26
I once tried NAPA for parts on a SMTA starter and they couldn't find the Delco number. Brushes are pretty common things so you can probably get those ok. You may also be able to match the bushings through NAPA. If you have shop that rebuilds starters and generators try there, usually they have or can get the parts for you.
