how to connect cultivator to a 200
three_deer
08-15-2006 14:30:55
I bought a Farmall 200 a few months ago and with it came a cultivator of some sort. I have no idea how it connect to the tractor. Can anyone help? I thought I could figure it out... it's got two clamps that look like they could clamp around the rear axle, it's got a wide flat mounting bar, and 2 smaller metal pieces that look like they'd connect to my hydraulics.
Randy in NE
08-15-2006 14:55:19
 Re: how to connect cultivator to a 200 in reply to three_deer, 08-15-2006 14:30:55
It sounds like you may have the rear mounted gang for the cultivator. That would bolt to the axle brackets and then have a lifting rod that would pass up along the seat and connect to the rockshaft on the hydraulic unit. It probably passes on the clutch side to that it can be operated independently of the front mounted cultivator. I'm not sure if the 200 mounts the same as the C but the C has three 3/4" tapered bolts right above the front wheels. Then they have lifting rods that connect to the rockshafts. Pretty easy to install.
