Super A Front U-bolt
Mikey D
08-16-2006 05:39:19
Before I bought my super A, some tom-fool removed the front axle U-bolt and tossed it. Now, I've obtained another one and must put it on. I'm hoping someone will know the answer to my question which is: Will I need to remove the radiator to get this job done? (I know I need to remove the hood and grill.)
Thanks.
Mike
Merlin
08-16-2006 07:20:53
 Re: Super A Front U-bolt in reply to Mikey D, 08-16-2006 05:39:19
Had to grin at that one. My name is Tom and I removed the U bolt from my Super A about 40 years ago during a repair job and haven't missed it one bit. If I ever figure out what it is for, I may just put it back on.
K-Mo
08-16-2006 14:18:33
 Re: Super A Front U-bolt in reply to Merlin, 08-16-2006 07:20:53
I don't know for sure, but I have always assumed the U-Bolt is there to minimize a left side roll over. Also, it allows you to jack both front wheels off the ground at the same time when jacking under the pivot pin.
K-Mo
Mikey D
08-16-2006 10:52:18
Oops! Sorry about that, Tom. No rudeness intended.
Mike
Andy Martin
08-16-2006 08:19:17
I just cut mine years ago. Can't remember it is gone most days.
gene bender
08-16-2006 06:03:28
Best thing is first get the threads clean so you can thread easy then you wont have to remove anything. Just stock it thru so only the thickness of the nut is thru. Then after putting top nuts on you can tighten from underneath. Will be fun but can be done. Much easier going on than taking off. Good luck
Mikey D
08-16-2006 10:50:22
 Re: Super A Front U-bolt in reply to gene bender, 08-16-2006 06:03:28
Oh, man! Why didn't I think of that? Great idea. Thanks.
mike
