starter generator
dustin47m
08-16-2006 10:09:12
what type oil do i use to oil the electrical components on my m would it be like three in one oil or like 30 wheight engine oil how many drops?
thanks dustin
Rob in Ore
08-16-2006 17:00:05
 Re: starter generator in reply to dustin47m, 08-16-2006 10:09:12
The manual for my 59 240 says that sae 20 is recommended. The genny and the starter are on the same schedule; every 6 months or 500 hours. For the generator, on the drive end fill the cup once; on the commutator end it varies from one to three drops depending on the type of generator. For the starter it says a few drops. Hope this helps.
Andy Martin
08-16-2006 15:01:48
Whatever goes in the engine is OK too.
Farmer Ryan from WI
08-16-2006 10:32:59
I use Three in One. The can I buy has a electrical motor onthe can. You only use a little of it. About 3 to 2 drops I use.
