Trike front end Q
Mike CA
08-16-2006 18:32:14
Are there two different types of Trike front ends for an H? I got that impression based on what someone said. I have the older front wheels... I guess they clamp on. And the newer ones bold on? Although there are 3 bolts around the outside of the center part. So I don't know. Regardless, are there two different types? Or will any Trike work with the wheels I have?
gene bender
08-17-2006 00:13:34
 Re: Trike front end Q in reply to Mike CA, 08-16-2006 18:32:14
The rims with the loops made the spacing of the fronts adjustable as to the width for muddy conditions or even the row crop spacing.
Steven@AZ
08-17-2006 00:07:13
There are two different hub/rim styles...
One uses cast iron clamps/wedges. (similar to the way the rear rims clamp to the hub)
One uses just bolts through loops that are riveted onto the rim. Nothing at all like a pressed steel car rim, just 3 loops on the rim.
Either will work just fine.
Andy Martin
08-17-2006 05:54:48
 Re: Trike front end Q in reply to Steven@AZ, 08-17-2006 00:07:13
To make it more clear, the rims and the hubs have to be the same style. I think you have the clamp style from looking at the WF picture you posted but I have not gone back and looked at the side view.
Ron in Nebr
08-16-2006 22:58:11
This "Trike" term kinda baffles me when I hear it being used for any front end that's not a "wide" front. Far as I know from the way I've always heard them referred to, there's 3 different front ends- a "wide" like you have, a "narrow" which has two wheels, and a "single" which naturally has only one wheel.
A single could be called a "trike" front. I've heard of a narrow(2 wheels) being referred to as a "trike" and I guess it does kinda make a tractor look sorta like a trike, but the term "trike" comes from the word tricycle- those things that the guy in the raincoat pedaled around on Laugh-In until he tipped over. The "tri" in the word "tricycle" referring to 3 wheels. So, a "trike" front end on a tractor couldn't really be any version that used two wheels for a total of 4 on the tractor.....
OK(with the nomenclature rant out of the way), the only narrow(two wheeled) front ends I've ever seen on an H use the same type wheels and hubs that you have. I think the same cast centers, wheel bearings, etc. too. If there's a factory narrow front out there that came with small hubs for pressed steel wheels(like the wheels you have on your car) I've never seen one. They could be out there though. Seen lots of wide fronts with those kinda wheels, although I suspect they're aftermarket.
A true "trike"(single wheel) front end I think would use a small hub with a shaft running through it that attached to the "forks" and a pressed steel wheel, although they werent common in this area and I've never looked at one up close.
CNKS
08-17-2006 20:13:35
 Re: Trike front end Q in reply to Ron in Nebr, 08-16-2006 22:58:11
I think the single fronts for the H came in 12 and 16 inch versions. Ours was 16, and it was cast, or forged, don't remember, it wasn't pressed steel.
