extra heavy gear oil
tn terry t
08-18-2006 04:31:04
not really about my old tractors but what is the heaviest gear oil available? i know 140 is pretty much standard but would like something heavier as always thanks terry T
Fred Milner
08-18-2006 10:01:17
 Re: extra heavy gear oil in reply to tn terry t, 08-18-2006 04:31:04
You can get steam cylinder oil up to 1000 weight and you my be able to get heavier but I have only gone to 1000. In the very old tractors it called for heavy steam cylinder oil in the transmissions. The 1000 is very thick and stays on the gears very well. You can get it from the oil distributors. The stuff I got was from Conaco. It was not very expensive and they had it in stock. I am thinking it was about $40 for 5 galons. They also has 680 and I got that for my W4 Mccormick but have not put it in yet. It has some loud gears in it. Fred.
dej(JED)
08-18-2006 07:32:05
I pump them full of grease sometimes. It quiets things down and last forever without a whole lot of leakage.
tn terry t
08-18-2006 05:58:23
i was wanting to put it the transmission on my h i messed up and put new gears against old gears and she is making a good bit of noise plus i just got an old A with quite a bit of slop in the gears just tring to quite it down for a while untill i can tear it apart
riverbend
08-18-2006 20:06:03
 Re: extra heavy gear oil in reply to tn terry t, 08-18-2006 05:58:23
Any chance of finding a used set or pair of gears and putting them in ? Old gears against new will wear the new ones very quickly.
Gary in Mozarks
08-18-2006 05:21:10
Ford used to use 600W gear oil in their steering boxes. (30's and 40's) I bought a quart of it from an antique ford parts place but I bet you can get it at a NAPA if you are willing to wait for them to order it.
City-Boy McCoy
08-18-2006 05:04:35
We used to make our own for steering boxes on race cars which were located near the headers. We mixed 140 and STP in a 50-50 ratio. Worked well for us in that application, although I don't know what you plan to do with it.....
mike
