Adjusting valves on 300u
Jimer
08-18-2006 07:19:00
Thinking about replacing valve cover gasket tomorrow on my 300 utility. But, with the discussions on checking valve clearance I am wondering if I should do that at the same time.
My questions are (1) Is this the clearance between the rocker arm and the end of the valve stem? and (2) what should this clearance be?
Thanks for reading!
Aces
08-18-2006 09:24:50
 Re: Adjusting valves on 300u in reply to Jimer, 08-18-2006 07:19:00
Jimer I would as long as you are in there you are right on(1) the book would say a little less than .020 but I set all H M 300 350 SM 400 450 at .020 never had problem with any.
