SA Generator Setup
Larry D. Grande
08-18-2006 07:56:58
Just bought a new voltage regulator and had the generator rebuilt. I need to make sure I polarize it correctly. I'm not sure how to do this. Can anyone give me the correct procedure to do this? Thank you.
John T
08-18-2006 10:56:38
 Re: SA Generator Setup in reply to Larry D. Grandey, 08-18-2006 07:56:58
Larry, you can do as Scotty suggested or else just momentarily flash jump a wire from the BAT terminal on the VR over to its ARM/GEN terminal and you should get a small spark. Assuming the wires in place n good from the ARM/GEN terminal on the VR to the gennys Arm post, thats doing the same thing electrically as Scotty suggested. I usually also first dead ground the gennys Field post to its case, but if alls well it ought to still polarize even without doing that. The genny needs a good frame/case ground to the tractor and the VR needs a good ground also you know.
John T
scotty
08-18-2006 10:16:18
Hi Larry, Momentarily touch a wire from the bat terminal to the gen terminal on the generator.
scotty
