1949 Farmall C Bad Rear Axle
Larry Senter
08-18-2006 16:16:30
I,m restoring my 1949 Farmall C. putting new axle seals on the rear axle. I found that the left axle is damage so bad at the outer bearing race I need to replace it. I haven,t did it before and I need someone to tell me what and how to pull and replace the axle.
thanks
Wayne Swenson
08-18-2006 16:36:46
 Re: 1949 Farmall C Bad Rear Axle in reply to Larry Senter, 08-18-2006 16:16:30
Easiest way is to remove the transmission top to gain access to remove the bull gear from the end of the axle. Makes it a lot easier to replace the gear later.
Securely block the transmission housing, remove the tire & wheel assembly, remove the cap screws holding the axle housing to the transmission, and pull the assembly out.
Replace the inner seal and outer seal while things are apart. Maybe do the other side also??
