IAA steering sector
gene bender
08-19-2006 13:17:58
has anyone removed the brace-pivot pin on a IAA steering sector? need to rebuild the unit but the brace-pivot pin seems real tight so is it a press fit?
Jim Becker
08-19-2006 17:47:14
 Re: IAA steering sector in reply to gene bender, 08-19-2006 13:17:58
Never actually removed one, but I know that when the 2 bolts at the bell housing are removed it will freely rotate away from the block. If yours rotates but won't push out, maybe a step has worn into it, hanging on the edge of the axle or housing.
GENE BENDER
08-20-2006 05:14:37
 Re: IAA steering sector in reply to Jim Becker, 08-19-2006 17:47:14
this one doesent rotate so will have to free it up. thats why i wondered if it was pressed in. thanks jim keeping warm in TEXAS better stop and see CALVINS new shed 60x125
Jim Becker
08-20-2006 08:12:35
 Re: IAA steering sector in reply to GENE BENDER, 08-20-2006 05:14:37
third party image
Another new shed since last spring? Or have I already seen it?
Weather has been what you might expect. Here is a picture I took last week of a yard stick I was using to measure a crack in my back yard.
gene bender
08-20-2006 09:11:58
 Re: IAA steering sector in reply to Jim Becker, 08-20-2006 08:12:35
He was here last part of JULY an said they had just finished it so you havent seen it yet. Picked up a restored 830D.
Jim Becker
08-20-2006 10:57:36
 Re: IAA steering sector in reply to gene bender, 08-20-2006 09:11:58
I guess I shouldn't be surprised!
