replacing clutch on a super H ?
worldsworstfarmer
08-19-2006 19:27:14
I know you can remove the clutch from an H without splitting the tractor. Helped my day do it several times. Now I have a super H that needs the clutch rebuilt/replaced. It looks different up there ( looking up though where the hydraulic lift was ). We used to take three bolts out, then screw them in exisisting holes to compress the pressure plate, then remove the clutch. I dont see those same three bolts. Need a little guidance here. Thanks, Gene
kfox
08-20-2006 05:27:59
 Re: replacing clutch on a super H ? in reply to worldsworstfarmer, 08-19-2006 19:27:14
Remove one of the bolts to check the length, then back the other bolts off evenly until the pressure is off. If you think you're going to run out of threads before the tension is off, replace every other bolt with one a little longer.
Worked on my old 49 Chevy 50 years ago. ken
CNKS
08-19-2006 19:35:54
I won't speak for all Super H's, but mine does not have the bolts either. I dropped the clutch, then decided the flywheel needed to be machined, so I split it anyway.
