424 lift problem
Gary321
08-19-2006 20:15:56
I have a 1967 gas 424 that runs great, the problem is the lift. When the hydralic fluid gets hot the lift jumps constently. I have replaced all seals & o'rings twice. When the fluid is cool the lift works great. Any suggestions would be helpful. Thanks
Gary321
08-21-2006 17:46:50
 Re: 424 lift problem in reply to Gary321, 08-19-2006 20:15:56
Thanks Haas, I"ll try that.
Haas
08-20-2006 18:57:25
If the unit is jumping, I think it is due to a leak in either the control valve or the cylinder. I used to have a 424 and it did that for a while and then eventually would not lift at all. It was the seal on the piston in the lift cylinder. Had to have a new piston and O ring to fix it. The original seal was leather, so had to have new piston to accomodate the more modern O ring. There is a shut off valve on the 424 that shuts off the hydraulics to the 3 point lift so you can connect a remote to the system. Raise the lift up and close that valve and shut off the tractor. If the lift goes down, the piston seal is leaking.
Gary321
08-20-2006 17:23:23
Thanks Bob, I have the regular IH service manual but I didn"t know about the other.
Bob
08-19-2006 20:34:03
There's several adjustments on that 3-point mechanism.
IH put out a "Blue Ribbon Service Manual" covering just the lift, and you really need one, if your are trying to adjust it.
