homemade 3pt -attempt post picture
sesser
08-20-2006 11:07:55
Machining parts at work during breaks. Getting close to piecing it together with welder. Is there a way to keep the ram from extending to its full travel? Should a chain go from the arms to the horseshoe to limit the upward travel as well as not let it swing out to the tires? If I did not make it myself,I would not get one, but it was more work than I like to do. I am more interest in getting the picture to post than anything else. Picture is copied from archives
Nebraska Cowman
08-20-2006 12:30:36
 Re: homemade 3pt -attempt post picture in reply to sesser, 08-20-2006 11:07:55
I use tinypic.com The pic must be uploaded to the web and then copy and paste the url into your message uing this code
third party image
SDE
08-20-2006 19:48:11
 Re: homemade 3pt -attempt post picture in reply to Nebraska Cowman, 08-20-2006 12:30:36
Welcome Home. That may have one of my errors. I will try again someday.
Keith-OR
08-20-2006 12:14:35
sesser, I have taken cylinders apart to replace seals, and found stops in cylinder (round collar slipped over the main ram, to restrict the full length of extention.) The length of the collar depended on the amount of restriction needed for the ram.HTH
Keith & Shawn
sde
08-20-2006 19:43:14
 Re: homemade 3pt -attempt post picture in reply to Keith-OR, 08-20-2006 12:14:35
Thank you very much. For now I am going to move the lower ram mount down one inch and I hope that will work out for me.
