1456 Getting to ME!!!!
pete76
08-20-2006 16:28:08
Having trouble getting the axle locks loose. Jacked it up, used 1" impact got bolt loose, inside wedge moves can't get the outside free. She slid all the way in-think it had doubles on all it's life. Does anyone know of a tool or an idea of how to break free. Need to slide out to fit wind rows. Thanks Chris-New York
Nat 2
08-21-2006 14:06:36
 Re: 1456 Getting to ME!!!! in reply to pete76, 08-20-2006 16:28:08
You need a wedge lock tool like Hugh describes. There is no way on God's green earth you'll ever get both wedges loose without it. Once you have the tool, you'll wonder how you ever got along without it.
pete76
08-20-2006 19:12:58
what kind of manual? IT does not show anything my father had IH dealership in the 70's parts manual dosnot show this wishbone just gives a part no. still trying to find the repair manual key book harvester put combines manurespreaders then maybe you will find something on a tractor. if i could find a picture of this tool i probably have it. cant ask my father he died 10 years ago . i was to small to work on this big iron back when he sold them. thanks chris
Hugh MacKay
08-21-2006 01:13:48
 Re: 1456 Getting to ME!!!! in reply to pete76, 08-20-2006 19:12:58
pete: Get an IH operators manual, wheel adjustment is part of operating adjustments and will be covered in the operators manual. Binder Books will have reproductions of the 1456 operators manual.
Keep the IT manual it does have some useful info but they omit some things.
Hugh MacKay
08-20-2006 18:36:40
It's time you had a manual. Those are quite simple but you must have the proper tool to loosen them. There is two U shaped irons that clamp on the wheel, by use of two bolt going through beside wedges. When the wedge that loosens first comes up against clamp, that forces second wedge loose. Those wedges are tightened to 600 ft lbs when put on. Using hammers will only damage bearings, and never loosen wedge if tightened properly in the beginning.
Aces
08-20-2006 18:31:15
Pete they made 2 dog bones to lay in the hub so 1 lock could not move with out the other. With out them I would bring the in side lock back snug then drive the tractor slow and use that brake to see it that helps.
