560 LPTO AND HYDRO PUMP SPEED
vance stanton
08-21-2006 10:59:21
I HAVE RECENTLY PUT A 560 REAR END IN A FARMALL M TO GET LPTO AND HYDRAULICS .I WILL RUN P.S. ALSO FROM THE PUMP IN THE SIDE OF T/A HOUSING. MY? IS ARE THE FRONT SPROCKETS THAT DRIVE OFF THE PRESSURE PLATE INNER CHANGABLE TO SPEED UP LIVE UNITS TO HELP WITH SLOWER M MOTOR. THANKS VANCE
Dave Slater
08-21-2006 18:51:50
 Re: 560 LPTO AND HYDRO PUMP SPEED in reply to vance stanton, 08-21-2006 10:59:21
If your rear has the clutch type PTO you can use the PTO drive gears from a 560 that was equiped with a planet PTO to speed it up.If I remember correct about one,the PTO would turn more than 540 wide open,needed to throttle down a little.If you change gears you need to change the one on hydraulic pump also because it runs off lower PTO drive gear. Thats why even though the LPTO drive gears from a SMTA,400 or 450 would give you the right speed with a planet PTO I don't know of a gear that fits hydraulic pump to drive it from those gears.
Dave Slater
08-21-2006 19:13:01
 Re: 560 LPTO AND HYDRO PUMP SPEED in reply to Dave Slater, 08-21-2006 18:51:50
Forgot to mention,if you have planet PTO now you can put clutch type in to speed up PTO. That would be less work than changing gears. Also hydraulic pump is going to be slower than in 560.
Wardner
08-21-2006 12:59:34
There are four gears:
SMTA/400/450 with planetary PTO .... 47 teeth
560 with planetary PTO .... 51 teeth
660 with planetary PTO .... 55 teeth
560 with clutch type PTO .... 70 teeth
These are the driven gear on the front PTO shaft. You will also have to change the driving gear up by the flywheel. Seems like you need the gear set out of the SMTA etc. Seems like they would interchange but I won't gaurantee it.
You need to take care that the gear bore is good. I have seen bad holes and it causes the gear to wobble. Prolly screws up the nearby roller bearing as well.
