IH 2400A Oil Pan Removal
T.C. in Tx
08-21-2006 19:16:04
I have a 1974 year 2400A loader tractor with a C-157 gas engine. Anyway, it blew the head gasket between the 3rd and 4th cylinders.
So, I figured I might as well replace the rings while I was into the engine. I don't have a chasis manual, but the best I can figure it looks impossible to remove the oil pan with the engine in the tractor frame.
Does anyone have any idea how difficult the job is to get into the bottom side of this engine? To me, it looks like the entire cast iron radiator frame and front end need to be removed as well as the frame rails back to the rear of the engine. Then it looks like the front part of the engine could be removed. But it looks to be very heavy and a difficult job.
For now, I went ahead and just installed a new head gasket. But I may need to get into the bottom end one of these days. The tractor only has 2500 hours on it, but it burns some oil and the compression is only at 125 pounds. The manual calls for 175 psi at cranking speed.
Any and all advice appreciated. Thanks.
El Toro
08-22-2006 04:50:44
 Re: IH 2400A Oil Pan Removal in reply to T.C. in Tx, 08-21-2006 19:16:04
You need to get a shop manual that covers your tractor if your manual doesn't have the pan removal procedure. Since this is a loader tractor your local Case/IH dealer probably won't
have the shop manual. IH sold off the loader division to Furival and I think they sold it too.
Midlantic Machinery in my area does these loaders now. Here's a web site for locating a dealer near you. You need to change the last two letters
to your state after the = sign. Hal
www.equipmentcentral.com/locator/customer/display.
cfm?region=North_America&territory=md
