HELP TA TROUBLE
redneckplowboy69
08-21-2006 20:41:38
I have a farmall 400 and the TA is sliping do i have to break the tractor in half to put a new TA clutch in
thanks jason
Kelly C
08-22-2006 20:04:09
 Re: HELP TA TROUBLE in reply to redneckplowboy69, 08-21-2006 20:41:38
Needs to look like this.
third party image
third party image
If you want to see how I replaced the TA in my 400. Click the link and find the Farmall 400 link on the left pane of my web site.
magman
08-22-2006 06:43:08
Make sure its adjusted acording to the manual. Then check Hytran as sugested. Does it whine when you pull it back? When the overrunning clutch was bad in my 300 it would whine like a child in the candy isle at first then go in. I can sell you a rebuild kit for that if you are interested. Alot cheaper than a unit or I can sell you a rebuilt unit also. JON
Wardner
08-21-2006 22:10:26
If you are not running IH Hy-Tran or equivalant, the oil can prevent the rollers from riding up the ramp and thereby locking the TA. That means slippage.
the tractor vet
08-21-2006 20:51:55
YEP not once but twice as the center section has to come out.
jpsep
08-22-2006 13:03:47
 Re: HELP TA TROUBLE in reply to the tractor vet, 08-21-2006 20:51:55
I thought the t/a in a 400 was a dry one???
