SEAL NUMBERS OF TRANNY AND BELLY PUMP
Ted form Maine
08-23-2006 14:38:03
I just lowered the belly pump on my H. Never repaired anything in this area before. I was wondering if any one can tell me the NAPA seal numbers for the following:
The seal number for the shaft the comes from the engine and goes into the tranny (need seal number for the seal at the tranny).
The seal number for the shaft that comes out of the tranny and drivers the belly pump. And the seal number where the shaft comes out of the engine (if there is one, besides the engine
main seal.And is there a seal inside where the input shaft goes through the belly pump housing. Thanks in advance for your most appreicated assistance.
kfox
08-23-2006 19:56:21
 Re: SEAL NUMBERS OF TRANNY AND BELLY PUMP in reply to Ted form Maine, 08-23-2006 14:38:03
Transmission driving shaft seal - CR18734
Transmission countershaft seal - CR13602 * I have in my notes that it requires 2 of these. Must be thin ones.
Hydraulic "Lift-All" pump seal CR13649
ken
Ted from Maine
08-24-2006 09:35:46
 Re: SEAL NUMBERS OF TRANNY AND BELLY PUMP in reply to kfox, 08-23-2006 19:56:21
Thanks for your help. I'm really on new ground working in this area of the tractor. Thanks again.
