farmall m wont run properly
derek schwartin
08-23-2006 15:48:56
thanks to all the ppl who told me how to get my m to run again. But now my m doesnt want to run by itself. Now it will only run when u keep the starter running. Do i need a new starter drive? Or any other parts? Thanks for looking but if u know please tell me
CNKS
08-23-2006 17:37:18
 Re: farmall m wont run properly in reply to derek schwarting, 08-23-2006 15:48:56
Did you remove the cables from the starting switch? If so the cable that goes to the battery and the wire that goes to the ammeter have to be on the same terminal. Otherwise the engine will die when you release the switch.
magman
08-23-2006 16:55:09
I would guess you have a balast resistor in front of you coil or somewhere there and its bad you need to go to the parts store and get a new one there usally under ten dollars and that should solve the problem JON
Marty Johns
08-24-2006 19:21:53
 Re: farmall m wont run properly in reply to magman, 08-23-2006 16:55:09
Try cleaning all terminal points!! neg. and pos. you would"nt believe the diff. this can make!!!!!
