traction control 450
glider
08-24-2006 03:41:35
How do you bypass the traction control on the 2 point fast hitch ? Going to pull a Farmall 450 for the first time, What do you think it weighs with fluid?
the tractor vet
08-24-2006 16:27:20
 Re: traction control 450 in reply to glider, 08-24-2006 03:41:35
Well i ain't going to tell ya how to cheat with a fast hitch but like others have said down and don't worry about the only ones that will wine will be the Jack Sheep boys if ya beat them as far as the weight if she has 15.5 x38's loaded i would say she is over 8500
RAW in IA
08-24-2006 14:42:46
There is a lever with a ring type handle on the lftside of the deck. It has several notches in it and pulles up and down. In the full down position the traction control is ionoperative. We had a 350 and never did use it. Kept it locked down.
jhb
08-24-2006 10:13:15
About 7000.
