bad exaust elbow,,what to do
ohjeffoh
08-24-2006 05:55:42
My exaust elbow on the 1256 has a hole through it, the problem is it's not original equipment, i don't know if it's m&w or something else and i don't know how to go about getting a new replacement since i don't know what i have. can i weld a patch over it? if so what kind of rod should i use? i tried brazing in a small spot but it didn't want to flow right.
ejr-IA
08-24-2006 07:24:24
 Re: bad exaust elbow,,what to do in reply to ohjeffoh, 08-24-2006 05:55:42
You can buy new after market elbows and sealing ring pipe.I replaced mine for around a 100.00 Most agg dealers can get the after market parts through A&I agg service in Iowa.
Dave from Texas
08-24-2006 06:12:39
JB Weld works good on manifolds if the hole is not to big. I also weld them with a Nickel or Cast Iron rod. Most of the time it works.
El Toro
08-24-2006 06:04:33
If you can remove the elbow, take it to your local
muffler shop and have a new one made. Hal
