Eureka, I saw the inside of engine on A
HENRY E NC
08-24-2006 10:44:39
I finally got the head off my 41 A and two pistons are definitely stuck, #3&4. This is a new adventure for a 75 yr old with a 51 M and now a 41 A. Never too old to learn. now all that stuff I have seen here on the forum will be put to the test
HENRY E NC
08-25-2006 06:20:33
 Re: Eureka, I saw the inside of engine on A in reply to HENRY E NC, 08-24-2006 10:44:39
Since I am learning I intend to remove the crankshaft and replace all the bearings.Is that proper way to go? Then I can drive the pistons out from above. I have a handicap , have two metal knees and two metal shoulders so kneeling is out and hamering up is out too. Thanks El Toro . Has been soaking for a month now.
Cedric
08-25-2006 03:25:11
I"m 75. Will be fitting new rings and bearings to my Super C within the next month or so. Did the transmission last year. Good to see us oldies still on the go. Good luck with the restoration.
Sid.
El Toro
08-24-2006 16:15:12
Pour some ATF on top of those pistons and let them soak. Drain the oil and remove the pan.
Loosen the rod and main bearing caps. After 3 or 4 days of soaking remove one of rod caps and use a piece of 2X2 oak and a big hammer to drive out one of the pistons. The sleeve may come with the piston since they're not pressed into the block. That's how I did an A. I'm 73. Hal
