Sputtering IH 464 Gas
PaJay
08-24-2006 18:04:15
While using my 1974 IH 464 gas tonight it started missing and sputtering under load. I gassed it up and black smoke came out of the exhaust. It starts and runs fine at low RPM but sputters now under a load and at higher RPM. Any suggestions on where to start? I took the carb off and cleaned it, it really wasn't that dirty.
Brownie 45
08-25-2006 05:27:45
 Re: Sputtering IH 464 Gas in reply to PaJay, 08-24-2006 18:04:15
How are the spark plugs? Borderline spark plugs with a little carbon/ soot on them will tend to misfire sometimes.
RustyFarmall
08-24-2006 19:06:55
Possibly could still be the carb, they aren't always that easy to clean, but I think maybe your ignition coil is getting weak.
the tractor vet
08-24-2006 19:30:02
 Re: Sputtering IH 464 Gas in reply to RustyFarmall, 08-24-2006 19:06:55
Yep that is what i am thinking or if the charging system is not working low voltage realy do not thing that it is a fuel problem.
