father in law took out rear PTO and cant get back
mikied
08-24-2006 20:06:58
The rear PTO for the mulcher was not staying engaged on the FIL's Farmall so he removed it to repair a sheared bolt, when he did the long shaft came out with it, which I gather is supposed to. The problem seems to be getting it aligned to put it back in, any help would be great because you know who will have to do it. Thanks
Mike
Harold Hubbard
08-25-2006 04:54:14
 Re: father in law took out rear PTO and cant get b in reply to mikied, 08-24-2006 20:06:58
I have always slid a long piece of pipe over the PTO shaft and used it as a handle. Don't know which model you are working on, but it may be a two-man job to lift it that way.
Jimmy King
08-25-2006 03:28:35
Get two long bolts the same size as the bolts that hold it in the tractor. and cut the heads off they will need to be long enought to get them out,but short enought to let you tip the unit to get the sucking tube over the edge of the hole in the back of the housing. screw them in the top holes and slide the unit on then.
