What options, if any, do Super M's have over M's?
ronnie-d
08-25-2006 06:55:30
Are there any base options that the supers have over the earlier letter models such as power steering, live hydraulics, etc.? I have owned M's and H's, but never a "Super", but I am looking at one today. I was just wondering what luxuries I would be gaining that I am not used to, if any.
bdm
08-25-2006 13:08:35
 Re: What options, if any, do Super M's have over M in reply to ronnie-d, 08-25-2006 06:55:30
I seem to remember that some of the bearing in the trans/axle are larger. Another thing I remember is the heat treated timing gear set for using a live hydraulic pump. I can't remember the details of what years or stages though.
Bob M
08-25-2006 07:31:36
Depends on when the Super M was built. The early production (Stage I) differences from a straight M consist primarily of a larger engine, different gearing (faster in higher gears) and disk brakes. Later production (Stage II) added live hydraulics, evidenced by the battery box relocated from beneath the gas to under the seat.
I believe however Stage II live hydraulics was a “delete option”. So there’s probably some Stage II Super M’s out there with belly pump hydraulics - or perhaps without hydraulics altogether.
Power steering was never offered for the Super M from the factory. However you’ll find many SM’s have been fitted with aftermarket Charlynn and Behlen PS kits by their owners.
John A.
08-25-2006 10:44:48
 Re: What options, if any, do Super M's have over M in reply to Bob M, 08-25-2006 07:31:36
Bob, Well said! Ronnie-d...also the Stage III Supers...AKA ,,the SMTA which had all that the StageI & II + TA and LPTO. That Super you are looking at could have any number of opitions to very few. Pull the tag # and see if it reviels anything.
Good Luck.
Later,
John A.
Andy Martin
08-25-2006 07:15:29
A little more fuel consumption along with a little more horsepower is about it.
The disc brakes are usually inferior unless they have been cleaned up.
Of course live hydaulics are nice if the tractor has it.
And the battery under the seat is pretty much of a pain to me. You have to have a wrench to jump it.
randy hall
08-25-2006 10:05:16
 Re: What options, if any, do Super M's have over M in reply to Andy Martin, 08-25-2006 07:15:29
why not hook the jumper cable to the starter? the straight m's are a pain to me to jump start or put a charger on with the battery under the gas tank.
Andy Martin
08-25-2006 14:40:38
 Re: What options, if any, do Super M's have over M in reply to randy hall, 08-25-2006 10:05:16
In my experience, maybe only mine, you get a better jump connecting to the lead connections on the battery. And you don't damage the starter post.
I guess I jump start a lot because I have a lot of old batteries and tractors without generators.
