Twindsor@aol.com
Tom Windsor
08-25-2006 21:18:34
I am still looking for 4- 3 7/16 servicable sleeves for an H. Too tight to buy new ones!
TW
Tom Windsor
08-26-2006 21:23:03
 Re: Doing it right? in reply to Tom Windsor, 08-25-2006 21:18:34
I looked it up in the book..."doing it right" The definition is:
1. It Runs
2. It don't smoke
3. It has oil pressure
4. It does not run hot and
5. it don't knock!
and if I were going to work the tractor and do more than start it up twice per year, I might spend $1,500.00 on parts. Gentlemen, thank you very much for your sage advice I have carefully written it down so I won't forget it.
T
El Toro
08-27-2006 04:31:25
 Re: Doing it right? in reply to Tom Windsor, 08-26-2006 21:23:03
You may be able to have the old 3 3/8" sleeves bored & honed to 3 7/16" by a good machine shop. Provided they're still tight in the block. They should have enough metal to do this. Hal
El Toro
08-26-2006 17:23:31
 Re: Twindsor@aol.com in reply to Tom Windsor, 08-25-2006 21:18:34
Well, if you don't want to spend any money to do it right, you may as well harness up the mules. Hal
Yugrotcart
08-26-2006 19:51:10
 Re: Twindsor@aol.com in reply to El Toro, 08-26-2006 17:23:31
If a jobs worth doin, it's worth doing right,,,,, ,,,,, ,,,,,
El Toro
08-27-2006 04:00:52
 Re: Twindsor@aol.com in reply to Yugrotcart, 08-26-2006 19:51:10
I had a teacher some 50 odd years ago always said,
"anything you do, do with all your might, because things done by halves are never done right". Hal
