Pressurized or not, Whats the difference?
sstractoranch
08-25-2006 22:47:40
I need to get a new radiator cap for my 49 H. Is the cap the only difference between a pressurized and a non- pressurized system?? How do I determine which one I need ?....Tom
RustyFarmall
08-26-2006 06:10:35
 Re: Pressurized or not, Whats the difference? in reply to sstractoranch, 08-25-2006 22:47:40
A 1949 H would have come from the factory with a pressurized radiator, possible it could have been changed over the years, but not likely. The pressurized cap will have a wing on it, the non-pressurized radiator cap will be round and smooth, will say "water" on it, and will interchange with gas tank cap.
NDS
08-26-2006 05:17:01
One way to tell is a gas tank cap will fit non pressure radiator but not pressure radiator.
Hugh MacKay
08-26-2006 02:26:52
SS: I think all Hs were presurized, at least by 49 they were. Some of the early ones may not have been presurized. I may be wrong but I believe all letter series tractors with water pumps were presurized. It was only small tractors using thermosyphon that were non presurized.
I may be wrong as I'm just going by the ones I've seen. I've never had a lot of exposure to pre 1950 tractors.
randy hall
08-26-2006 13:08:32
 Re: Pressurized or not, Whats the difference? in reply to Hugh MacKay, 08-26-2006 02:26:52
hi hugh, the pressure radiators on h's and m's started during world war ll. they started using steel instead of copper for the fins and went to the pressure system to raise the boiling point due to the not as good heat exchange. i have had a couple of these tractors and the fins were rusting off the tubes.
Nebraska Kirk
08-26-2006 11:13:13
Hugh, my H was made in May of 1942 and it is not presurized.
Wayne Swenson
08-26-2006 05:44:56
Some early H"s were non-pressurized. Look at the grill and neck of the radiator. Is there an overflow tube coming out of the neck of the radiator? Is there a groove cut in the grill opening to make room for the overflow tube?
RustyFarmall
08-26-2006 06:14:29
 Re: Pressurized or not, Whats the difference? in reply to Wayne Swenson, 08-26-2006 05:44:56
Also, the early, non-pressure version used the dzus fasteners to hold the grill to the radiator.
Steven@AZ
08-26-2006 06:46:16
 Re: Pressurized or not, Whats the difference? in reply to RustyFarmall, 08-26-2006 06:14:29
Nope, they made the change over to pressurized sometime in 42. My early 42 H has non-pressure radiator. My late 42 I believe has pressurized.
I think the dzus fasteners were only on the 39 models...
NDS
08-26-2006 08:48:39
 Re: Pressurized or not, Whats the difference? in reply to Steven@AZ, 08-26-2006 06:46:16
I would think that H and M would have changed about same time and Dzuz fasteners were used on M through SN 24214-late 1940 and non pressure radiator was used through SN 60244-early 1943. This is from parts book may be wrong.
Steven@AZ
08-26-2006 10:24:30
 Re: Pressurized or not, Whats the difference? in reply to NDS, 08-26-2006 08:48:39
I stand corrected on the dzus fasteners.
I'm pretty sure that my late 42 H has a pressure cap on it... just don't remember 100% for sure.
Thanks for the clarifications, guys!
RustyFarmall
08-26-2006 12:41:08
 Re: Pressurized or not, Whats the difference? in reply to Steven@AZ, 08-26-2006 10:24:30
Steven, when the changover was made, the non-pressure style was made obsolete, and the only replacement radiator you could get was the new pressurized style, which means that even if the tractor was originally a non-pressurized, it could very easily now be the newer style.
RustyFarmall
08-26-2006 07:00:40
Nope, my 1940 with June casting codes has the dzus fasteners.
