H gas tank cap
Skip
08-26-2006 09:01:09
I've got a 1950 "H" and the gas tank cap leaks a little when the gas sloshes around, especially if I fill the tank almost full. Anybody have a solution other than buy a new cap?
Thanks in advance for your info. The guys on this website have been a very valuable source of information in the past and I appreciate it! Thanks again!!!!
Skip
08-27-2006 09:50:28
 Re: H gas tank cap in reply to Skip, 08-26-2006 09:01:09
Thanks IHNut! And the others, too!
I had no idea about the gas cap giveaway. Just goes to show, if you don't ask.....
IHnut
08-26-2006 18:53:03
Go to... www.ihgascap.com/index.aspx This offer is good till 5 of 2007.
They sent mine with no problems. Just took awhile.
Wayne Swenson
08-26-2006 13:34:43
Is the top of the filler neck smooth so your gasket can make decent contact and seal properly?
Janicholson
08-26-2006 09:45:51
Use the Gas Cap form (search Archives) to send for a replacement free cap (you need the complete serial number for the form. I do not know how long they will continue the program, they had a big push about six months ago (my brother got 8 caps 6weeks after applying). JimN
Farmer Bob
08-26-2006 09:41:04
Many have had the same problem even with the new baffled replacement taller caps. You may try your local Case NH dealer parts desk to see if they have a new gasket for your old cap or simply visit your local auto parts folks and try to find a new gasket to fit under the tangs of your old cap. When all else fails, I make mine out of high density 1/8" sheet cork cut to fit.
