Delco alternator output
Justin S. - TX
08-26-2006 10:45:28
In the process of converting my C to 12v. When I checked the voltage output from the alternator it was less than 1 volt. Is this normal, or is there something wrong.
El Toro
08-26-2006 13:58:03
 Re: Delco alternator output in reply to Justin S. - TX, 08-26-2006 10:45:28
Here's a web site for Bob M's alternator/generator
troubleshooting procedure. Should be one on there to cover you tractor. Hal
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=63226495&/=0
old
08-26-2006 11:20:35
Either you have a bad alternator or you have it wired wrong. With the engine running you should have around 14 volts acroos the battery and if its not running about 12.5 volts. Sounds like the wire to excite the alternator isn't wired right or its not exciting for some reason. The way it should be wired is. #1 terminal from the little plug goes to the swithc with either a lite or diode in line, #2 to the big post on the alternator and the big post to the battery of soliniod.
