Farmall 1206 will not engage into reverse
farmer2000
08-26-2006 16:35:17
I have a 1206 and it doesnt seem to engage into reverse I am not sure if the reverse gear is missing teeth or somthing else, Have any ideas
thanks
Brownie 45
08-27-2006 06:00:59
 Re: Farmall 1206 will not engage into reverse in reply to farmer2000, 08-26-2006 16:35:17
Does it go into the other gears OK ? Are they close to being in alignment with where they should be according to the shifting quadrant? If not , check that the roll pin is in good shape on the shifting shaft that goes down into the transmission. The neighbor had this trouble, & it was this roll pin that was shot. New pin fixed things up.
migraine
08-27-2006 08:49:36
 Re: Farmall 1206 will not engage into reverse in reply to Brownie 45, 08-27-2006 06:00:59
I bought an 806 Diesel a few years back that the I.H. dealer had told the customer would take 7000 dollars to get the transmission repaires cause it had broken a shaft inside. Well those old 806 and 1206 were about as tough as nails so I drove it on the trailer in forward and eased it off the trailer into the shop and pulled the inspection plate under the left or clutch area and found it had one broken ear off the shifting fork so it would not pull the linkage into reverse. Got one from the salvage yard for 4 bucks and put in and walla walla we now have put 200 hours on the old girl and going strong. I paid 1200 dollars for the tractor at the dealer. Migraine
