Order Farmall Cub Parts Online
cub loboy rear seal?
george mcnaught
08-26-2006 17:41:47
ih cub loboy,serial #18865j with c60 engine.need to replace rear main seal.old seal is rubber coated with no # on it.ordered cr29887 from napa which is a metal base seal.id seems correct but od is too small as it is loose in seal retainer.where can i get the correct seal & number?
Merlin
08-27-2006 02:56:01
 Re: cub loboy rear seal? in reply to george mcnaught, 08-26-2006 17:41:47
I personally have never tried this, but I have heard some guys say they use JB Weld on theirs to hold it. I use high temp Salastic. Not sure of the number of it right now. Two things for sure, it will probably leak if you don't use something, and there are as many answers as there are Cubs that need rear seals. I don't know why IH quit making the original seal, but I haven't found one yet that will replace it without gooping it up with something to make it stop spinning in the housing.
john *.?-!.* cub owner
08-26-2006 19:32:28
There is a problem that Ih changed the seal retianer at some poitn ( don't know when)and the orignal seal is no longer available either form IH or form aftermarket suppliers. You can either order a new retianer (over $100) or use a selaer or bearing seat type material to hold it from spinning as well as staking the reatienr to tighten it.
Roger46
08-27-2006 18:50:05
 Re: cub loboy rear seal? in reply to john *.?-!.* cub owner, 08-26-2006 19:32:28
John, I am rebuilding a Cub and when I reassembled the engine that rear main seal didn't fit loose. Could I have a new seal housing? Before I bought it the engine had been recently "rebuilt" in that it had been bored out and some parts replaced. I got the gasket set with the seal in it from NAPA when the NAPA machine shop finished the rebuild for me. Roger
Roger46
08-26-2006 19:10:59
George, My Cub parts book calls for that seal to be an IH part# 364 692 R91.
