carb kit for an H
Charlie M
08-27-2006 10:17:51
Anyone bought a carb kit from the dealer lately -just paid $91 for one this weekend.
Fancy Farm
08-27-2006 12:27:17
 Re: carb kit for an H in reply to Charlie M, 08-27-2006 10:17:51
TSC has 2 kits for a H farmall one is basic the other which is the $37 kit has the packing and the shafts works as well as the CNH parts I have bought
Elk Farmer
08-27-2006 10:55:06
Bought mine from Tractor Supply for $37.50 seems to work fine. The only thing it did not have was a new throttle butterfly.
RustyFarmall
08-27-2006 12:06:03
 Re: carb kit for an H in reply to Elk Farmer, 08-27-2006 10:55:06
Elk farmer, if you ever get a chance, compare the TSC kit side by side to a Case-IH kit. Take the various parts out of the package and hold them in your hand. You will quickly realize why the Case-IH kit is more than double the cost. I have used the cheap kits also, it is very rare to get a cheap kit that actually has ALL of the parts in it that are supposed to be in there. There will just about always be at least one piece missing, sometimes more than one, and usually the gaskets do not fit properly. I think it is safe to say that the TSC kit did not come with a new packing gland for the load adjustment screw either.
Elk Farmer
08-27-2006 17:08:00
 Re: carb kit for an H in reply to RustyFarmall, 08-27-2006 12:06:03
Rusty
Actually the kit did come with the packing for the high speed adjusting screw. Matter of fact you instructed me how to use the packing and thank you for the good instructions no leaks.
The tractor runs great.
I'm sure the more expensive kit has all the correct parts but the one I bought worked fine.
Carl from Michigan
third party image
RustyFarmall
08-28-2006 13:48:52
 Re: carb kit for an H in reply to Elk Farmer, 08-27-2006 17:08:00
Elk Farmer, that is very encouraging to hear. Maybe these aftermarket manufacturers are finally getting it right? I think the TSC kits are made by Tisco, if so, a big thumbs up for them.
CNKS
08-27-2006 10:52:29
Quality costs money -- you won't need another for a long time. It also costs Case-IH money to keep suppling parts for almost 70 year old tractors. That probably has as much to do with it as anything.
