826 Brake problem
Centaur Nut
08-27-2006 10:38:58
I just got my 826 Hydro going after being parked for many years. I've changed all the fluids & filters and everything is working good except the brakes. They work, but you have to pump them up. I've bled them but it didn't help. Suggestions?
Sheepdog in NE
08-27-2006 19:26:44
 Re: 826 Brake problem in reply to Centaur Nut, 08-27-2006 10:38:58
I guess I would take them apart and make sure they aren't wore out. The stoppers in the housing might be touching. That keeps the piston from falling out of it's machined area. New discs and a o-ring seal kit will fix that. If that's it. If you find they are OK then will talk again.
Centaur Nut
08-27-2006 20:22:23
 Re: 826 Brake problem in reply to Sheepdog in NE, 08-27-2006 19:26:44
I appreciate the help! I'll pull them off tomorrow & see what they look like.
