460/560 manifold
Tim Shaw
08-27-2006 11:26:17
Is the exhaust/intake manifold the same on the Farmall 460 and 560 gasser? Need one on one of our 460s and have one located from a 560.
Broomstacker
08-27-2006 19:05:19
 Re: 460/560 manifold in reply to Tim Shaw, 08-27-2006 11:26:17
Me, too! Wonder why these bloomin things are so hard to find!?
INTom
08-27-2006 18:31:54
Tim,
If you find an extra one, let me know. I am having my 460 gas manifold welded and if it cannot be saved, I will be in the market for one too. Thanks
Rockytop560
08-27-2006 18:10:55
Yes, they"re interchangeable.
migraine
08-27-2006 19:28:49
 Re: 460/560 manifold in reply to Rockytop560, 08-27-2006 18:10:55
The manifolds from the 221, 263,291,and 301 gas motors should all be interchangable. This is basically the same block with just different sroke and bore. I bought two aftermarket manifolds a few years back but had to put a slight angle in the upright pipe to use the existing hole in the hood on the 560,s. they have held up well with no problems but if you can find an original that would be great. Most of the tractoras that come in the salvage yards here have big holes in them or cracked beyond repair. Tractor models that you are looking for are 460,560,656,706 and 666 gas models. Hope this helps. Migraine
